LS XR4040
/ LS XR4040 #1
Sandyhill
LS XR 4040
Hello, glad to be here and looking forward to be part of this community. Recently bought a LS XR4040 and looking to see all the pros and cons of this tractor
/ LS XR4040 #2
Welcome to TBN! I have a LS XR4046 which is the brother to the 4040. Great machine to have. I just did the 500 hr service on it, and it has been trouble free. I had 1 small leak which was fixed by my dealer at the 50 hr service. I keep the rpms around 2000 or more, and it regens about every 4 hrs. The only way I know it happens is by the dash lights. No effects while working it.
/ LS XR4040
How many hrs on your 4040?View attachment 617030
My XR4040 has 560hrs on it. I'm a little worried about the the then cycle. You yours regens every 4hrs, but mine runs about 2-2 1/2 hrs before it regens and the other day it took 4hrs to complete a regen. I'm not sure why it took so long, but I have replaced fuel filters since then so we'll see if that will help it take less time.
/ LS XR4040 #4
Congrats on your new to you tractor and welcome to TBN.
Generally it regens every 4-5 hours. It should NOT take 4 hrs to regen but should complete in 40 min. or less. When it does regen you need to keep the RPM's up (between 23-2500). It needs the higher RPM to regen efficiently. Idling or running just above is not good to do on a regular basis. These engines are meant to run at higher RPM's. I have the XR3037HC little brother to your 4040 with the same engine. Once warmed up I generally run between 22-2400RPM. Only a little over 300 Hrs on mine but main use for mine is winter snow plowing.
/ LS XR4040
I am thinking about deleting the dpf, biggest reason is that this is a gear tractor and using the loader a lot.that means I have to park the tractor and run it on high rpm.
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A64553)
2006 Generac...
(12) Round Bales of Hay (A65640)
(12) Round Bales...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
1995 Skeeter 300ZX Bass Boat (A65579)
1995 Skeeter 300ZX...
