LS XR3037 Ground Clearance Issues?
   / LS XR3037 Ground Clearance Issues? #1
Hdoilcan
USA
2018 KIOTI CK3510SE CAB, 2475L BACKHOE, 72 BOX BLADE, 72 REAR BLADE, 72 LANDSCAPE RAKE, 1,250 LB 55 GAL DRUM BALLAST, 2018 FERRIS IS 700Z, 26HP 810 VANGUARD ENGINE
The XR3037 I believe from seeing in another thread has 8" of ground clearance. Has anyone run in to issues with this...... especially in the wood or where there would be ground debri? Seems like 8" is low compared to 12"-13" I've read on other cuts.
   / LS XR3037 Ground Clearance Issues? #2
I don't have a 3037 but 8" doesn't sound right. Maybe George2615 or Maxify55 can get a measurement for you.
   / LS XR3037 Ground Clearance Issues? #3
   / LS XR3037 Ground Clearance Issues? #4
I measured mine at 12 1/2". Never had an issue with hanging up or dragging.
8" is what I have to the bottom of the loader support structure. You probably read my post linked here. I think others that own the XR4040 & 4046 mention 12.5" on their models. I don't spend any time in the woods to worry about clearance issues.
https://www.google.com/url?q=http:/...ds-cse&usg=AFQjCNGBS_mQ-tr6S9tbqf1XiK3CZfhr7g
Yes that was the post. I won't really be doing anything in the woods either but have a few acres to clear. I'm not sure what's in/under all that tall over grown grass so just curious of ground clearance for when I tackle that job. On the side of my property I have water that just runs onto to the property from a drainage under the road. Over the years it's just made its own path. The ground is very uneven so that's another reason to be curious about the ground clearance when I tackle that also.
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
Skid steer auger plate (A50322)
Skid steer auger...
2018 New Holland C227 Compact Track Loader (A55302)
2018 New Holland...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
