ls xr 4145 hc cab top removal
   / ls xr 4145 hc cab top removal #1
deer assassin
Kingston Springs TN
2017 LS XR4145HC 1967 oliver 550 gas
Has any one ever removed the cab top ?
i pinched it on a tree and cracked a hole in it. I just want to remove it and bondo it up
thanks
   / ls xr 4145 hc cab top removal #2
There are 2 nuts in front of the cap behind the lights and one on each side about the middle of the door areas then the entire top is hinged at the rear. I have a XR3037HC, my buddy has an XR4140HC and both caps are attached the same.
   / ls xr 4145 hc cab top removal #3
It's easy. As stated by George, remove the two nuts right above the doors (they maybe covered by plastic caps) and two behind the front lights. The entire thing will hinge up. Removing the hinge should be straight forward. Mine has a kick stand that was zip tied down inside to hold the cap up. Of course, you will need a 10mm and ladder for this (and snips for the zip tie.)
   / ls xr 4145 hc cab top removal #5
OHH!! Just remembered. When you reinstall those nuts, a dab of locktite. One of mine rattled loose. I found the nut on my driveway, and took me a while to figure out where it went. :laughing:
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2018 CATERPILLAR...
11 ft Shipping Container (A55973)
11 ft Shipping...
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
