LS XR 4046 or LS XR 4046H
   / LS XR 4046 or LS XR 4046H #1
seowens101
Clayton, GA
none
I am still trying to decide which tractor I want to buy. Can some of you help me understand the pros and cons between sychronized shuttle and the hydrostatic. I will use the tractor on a 24 acre mountain farm that is terraced. Mostly it will be used for plowing, tilling and mowing. I will use the FEL some but not extensively. I will also use it skidding a few logs for firewood.:confused:
Thanks,
Stanley
   / LS XR 4046 or LS XR 4046H #2
Welcome to TBN.........
For what you describe for usage I'd go with shuttle. HST would be better if you did a lot of loader work and repetitive forward and backward motion.
Shuttle would also be less $$$ than HST.
Good luck in your search.
   / LS XR 4046 or LS XR 4046H #3
I agree. I don't like Hydros for mowing, especially in hilly areas.
Eugene
   / LS XR 4046 or LS XR 4046H #4
I have a hydro and I agree. If you are going to be tilling and such go with the shuttle.
   / LS XR 4046 or LS XR 4046H #5
I agree with everyone above. If not much loader work, go with the shuttle.
Thanks guys. I was leaning toward the Hydro so I really appreciate the input. I think I have changed my mind and will go with the shuttle.
Best Regards to all,
Stanley
   / LS XR 4046 or LS XR 4046H #7
I have a hydro 4046 I like it I juat wish it had more pushing power esp in 2nd gear.
   / LS XR 4046 or LS XR 4046H #8
I've got a XR4040 and thought about the hydro because I do a lot of FEL work. Now that I've got the shuttle I can't see the hydro being worth the extra money to me. Plus I hated the herky jerky of stopping with the hydro. I assume that would have got better as I used it more though. My terrain is fairly rough and a hydro would cause problems there I assume. The foot throttle is useless to me as it is.
   / LS XR 4046 or LS XR 4046H #9
Well the jerkiness of the hydro goes away after you get use to it. I have a rough pasture that I mow and disk and it doesn't affect me on the pedal. Its also to small to use the cruise on it so I just manually press the pedal. One thing that it will do is save you from hitting something. i have almost gotten into my fence but the first instinct you do is snatch you foot off the pedal and it will come to a quick stop. Also I have a little one that I ride in there with me and I couldn't hold him and use the shuttle lever. So i have the perfect set up for me.
   / LS XR 4046 or LS XR 4046H #10
Yeah, we have a XR4046HC and mow with the cruise control all the time. Our big tractor, a NH 100 hp gear tractor works okay for mowing but prefer the Hydro LS.
Sent from my iPad using TractorByNet
2016 Ford F -150 (A50323)
2016 Ford F -150...
2016 HITACHI ZAXIS 210LC-6N EXCAVATOR (A51242)
2016 HITACHI ZAXIS...
Caterpillar 60in Pallet Fork and Frame Attachment (A49461)
Caterpillar 60in...
72In FEL HD Round Back Bucket (A51039)
72In FEL HD Round...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
