LS xj2025 will start, but when I let go of key, the tractor dies.
   / LS xj2025 will start, but when I let go of key, the tractor dies. #1
7redleaf
LS XJ2025
My tractor will start, but when I let go of key, the tractor dies. Any idea what the problem could be?​
   / LS xj2025 will start, but when I let go of key, the tractor dies. #2
Presuming this is a diesel does the fuel shut off solenoid have two or three wires? If two wires one should have power with key in the run position. If three one wire is ground, one is pull in that is energized for starting and 3rd is holding which stays energized while engine is running. I would start by checking to see if you are getting power to coil with key in the run position.
   / LS xj2025 will start, but when I let go of key, the tractor dies. #3
Continuing with the above thought, even if the run lead is getting power it's possible that winding is defective and not holding the valve open. Make sure you're getting full voltage and go from there.
Do you think it could be the fuel filter as well?
   / LS xj2025 will start, but when I let go of key, the tractor dies. #7
No, your problem is not the fuel filter. I think you have an issue with the run circuit.
CASE INTERNATIONAL 3950 - 21' DISC HARROW (A52708)
CASE INTERNATIONAL...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
2012 Kenworth T660 T/A Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T660...
2020 DRAGON ESP...
2015 Honda Accord Sedan (A56859)
2015 Honda Accord...
