Oil & Fuel LS XG3140 HST fluid
   / LS XG3140 HST fluid #11
303 is made for older tractors and should not be used.
   / LS XG3140 HST fluid #13
I went back to my dealer and purchased the 5-gallon pail of LS hydraulic fluid. Do I need it, dunno, but I’m not gambling my new tractor of the hydraulic fluid price alone. My last hydro was a New Holland so I used their fluids and 23-years later had no issues related to fluids. Your results may vary
   / LS XG3140 HST fluid #14
Please do not use 303!!! Any good quality name brand hydraulic oil is OK. For a hydrostatic transmission you should use the best oil you can buy, and lots of oils are very good, but synthetic is the best. It says on the 303 bucket that it should not be used in any machines made after 1970, and it does not meet any specifications for modern equipment. It is cheap to buy because it is made with unknown low quality base oil and other questionable ingredients, and has no additives in it like viscosity stabilizers, anti-foam agents, anti-wear or moisture resistance like good quality oils have. There was a class action lawsuit against the companies marketing 303 because it is very poor oil that does not meet the standards that they claimed it did. Unbelievable that a dealer would tell you it was OK to use that crap. They obviously know nothing about oil or warranty. LS warranty policy specifically states that failures from using improper lubricants are not covered, but how would they find out? They are getting stricter on warranty, but they don't require an oil sample for analysis when submitting a warranty claim like the big farm equipment manufacturers do. (Not yet.)
   / LS XG3140 HST fluid #15
I use chevron thf 1000. Good stuff, with long known history of top performance in different applications.
I myself avoid 'farm supply store brand' oils and stick to known brands like chevron, Union 76, mobil and such.
I do also use dealer oils like deere, and new holland. There oils are custom blended from top oil companies to there specifications and often cross over to other manufacturers specs.
   / LS XG3140 HST fluid #16
I ended up not using the 303,went with NH ambra g-134 5 gal bucket.
   / LS XG3140 HST fluid #17
Good choice.
2014 Ford F-550 (A55973)
2014 Ford F-550...
2010 CHEVROLET SILVERADO 3500 HD PICK UP TRUCK (A57880)
2010 CHEVROLET...
Mini Margaritaville Truck (A55853)
Mini...
2007 Yamaha Rhino 660 (A55315)
2007 Yamaha Rhino...
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
