LS XG3025 3-point lift Stabilizers
   / LS XG3025 3-point lift Stabilizers #11
I have attached a photo showing the hinge on the stabilizer. When I have the piece of equipment centered and the pin in place and go to the other arm and stabilizer and try to place the pin in that stabilizer the original one just swivels at the hinge. I really don't know how to explain this any better but maybe the photo will help. Do your stabilizers also have a hinge on the end that attaches to the tractor?
Yes, I usually pull that little swivel thingy tight, then put the pin in. Essentially keeping it as straight /tight as possible. The same is repeated for the other side.
With these links, you will never get the attachment absolutely tight (which you don't want to do anyway).
   / LS XG3025 3-point lift Stabilizers #12
Like other say, they work on tension rather than compression.
But while you are still thinking about your 3 pt, change those square head pins to one with a flat face. Those stupid square heads tend to rotate, grab, and then bend your stabilizer bar.
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56438)
2006 Heil Tanker...
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
8 sets of Jumper Cables (New/Unused) (A59225)
8 sets of Jumper...
2020 John Deere 1025R MFWD Compact Tractor (A56438)
2020 John Deere...
KMC 4R TOOLBAR (A52708)
KMC 4R TOOLBAR...
John Deere 3025E (A53317)
John Deere 3025E...
