LS Tractor Oil, Gas, & Air Filter Information
   / LS Tractor Oil, Gas, & Air Filter Information #401
I think mine is a plug. My tractor is am MT3 52 tho... looks about the same in your pic. Where did you get your service manual??
I only have a digital version, I think my Dealer sent it to me or someone on here has them and I downloaded it
   / LS Tractor Oil, Gas, & Air Filter Information #402
might be a dumb comment, but how does the plug come out of the replacement filter? Maybe fiddle with that one, not the live one, if you haven't though of that. And I'm interested as mine is coming due and might replace it anyway to see if it helps the regen issue.
Dealer want's "The price is $77.48. PN# 40271228" and a WIX WF8395 is $19.42 on Amazon and $13.99 at the local O'Reilly auto parts store, so I'm interested if it fits lol
   / LS Tractor Oil, Gas, & Air Filter Information #403
The LS Fuel Filter 40271228 water-in-fuel-sensor at the bottom of the fuel filter is threaded in.
The WIX version comes with a black screw in plug/drainer as seen below. It did screw right into the LS filter perfectly. The top side of the WIX looks to be a thread match as well.
The LS filter does feel heavier.
   / LS Tractor Oil, Gas, & Air Filter Information #404
It is a photo illusion or is the wix filter diameter a good bit smaller? The main body seems the same, but the mating surface looks a lot smaller in the picture, might be because the stock is closer to the lens.
Defiantly shorter which could account for the weight difference.
   / LS Tractor Oil, Gas, & Air Filter Information #405
Mostly optical illusion, but it is slightly smaller diameter.
   / LS Tractor Oil, Gas, & Air Filter Information #406
Here is the filter list for my MT3 52HC. Note that these are specific to my chassis SN. There are some differences in the hydro and HST filters based on SN
Oil-40409065
Fuel-40271228
Inner Air-40049446
Outer Air-40007576
HST-40383187
Hyd-40347273
Shout out to folks at Legacy Tractors. They helped me with the right part numbers and make it easy to order all the filters you need online from them. Legacy Tractors Online
   / LS Tractor Oil, Gas, & Air Filter Information #407
Do we (who own LS tractors) need a sticky with oil, gas, air filter information?
I will add that from what I gather the following info is for the R4010:
Wix filter info:
Fuel Filter P/N 33128, Engine - Mitsubishi S4QL Engine
Oil Filter P/N 5106453, Engine - Mitsubishi S4QL Engine
Air Filter P/N 46438, Donaldson P/N P821575
WIX Filters : Filter Look-Up
Fleetguard:
Wix 46438 & Napa 6438 Air Filter: FleetFilter Secure Online Store
Napa 6438
NAPA Online
Fram Air CA9550:
Search Results
Gravely Air PP30055
Gravely 21537000 Replacement [PP30055 Grave] - $13.76 : 491588, Air Filters, Air Filters, Oil Filter for small engines
Fram Oil:
FRAM - Part Details
Also here is some info on the filter for other manufacturers models with the same engines etc. but youll have to do some cross referencing:
tractor_filters[1].pdf - File Shared from Box.net - Free Online File Storage
If you do want a Sticky - Lets contact a Moderator, like:
TractorByNet.com
Or if you know of one.
If not, so be it.
Yes, good post. I have an XR4140, so apparently has the LS engine and not the Shibauru engine. Some numbers are definitely different for me...depending on which site I look at (NAPA, Donaldson, CNH, LS, Messick's, etc.) Very confusing.
   / LS Tractor Oil, Gas, & Air Filter Information #408
508 hours and still pretty decent. I blow out the outer one regularly from inside out.
Replaced with same Donaldson P822768 & P822769 Air Filter Set as stock.
https://www.amazon.com/dp/B01IFB4JMA was $58 when I ordered them.
Pics inside old filters
   / LS Tractor Oil, Gas, & Air Filter Information #409
LS MT352 Engine oil filter wix57085 or luber finer lf 16011
   / LS Tractor Oil, Gas, & Air Filter Information #410
The WIX WL7426 oil filter does NOT fit my MT240HE, it's too tall and interferes with the loader support. Just FYI.
I thought I had a LS filter but don't so now I have to scramble to see what I can find that will work. no LS dealer within an hour.
Edit: Well, we have a new dealer 40 minutes away come to find out and they have them in stock! Road trip!
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2121 (A51244)
2121 (A51244)
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
