LS Tractor Oil, Gas, & Air Filter Information
   / LS Tractor Oil, Gas, & Air Filter Information #391
As for the fuel filter, it cross checks,
   / LS Tractor Oil, Gas, & Air Filter Information #392
re: LS Tractor Oil, Gas, & Air Filter Information
I changed my Motor oil, motor filter and Hydraulic filter in my 5020c...I did not change the hydraulic oil but buy a gallon of it cause you will lose some when you change the filter..
An FYI the oil filter is on there HARD..and there is no room to work..luckily a buddy of mine had an oil wrench with some teeth cause i couldnt get it off even punching a screwdriver thru the filter. There was barely any room to turn the filter too once the screw driver was in there..
Not only the oil filter but the hydraulic filter is an absolute bear to get off of an MT 342. The wrench that works with all of them is the Channellock 480 BigAzz. And grip the filter right where it meets the tractor. That is a heavy metal plate. Otherwise, you just crush the filter and tear it. I don't know why LS put them on so damn tight. Its ridiculous.
   / LS Tractor Oil, Gas, & Air Filter Information #393
I ordered these Wix and Donaldson filters all through Amazon for much less than listed above.
Oil filter / OEM # 40409065 / Wix WL7426 $19.81
Fuel filter / OEM # 40271228 / Wix WF8395 $18.51
Hydraulic Filter / OEM # 40007638 / NAPA # 1715 / WIX 51715 $43.00
Hydro Transmission Filter / OEM # 40007563 / NAPA # 1551 / WIX # 51551 $11.17
Outer Air Filter / OEM # Donaldson P822768 / 40007576
Inner Air Filter / OEM # Donaldson P822769 / 40049446 $64.00 for the set
If the Oil and Fuel filter don't fit, I can return or I'm not out much money.
Any issues with the aftermarket fuel and air filter sets?
   / LS Tractor Oil, Gas, & Air Filter Information #394
Haven't installed the fuel filter yet.
The Air filter set is actually what came on mine and not really aftermarket, they have Donaldson and those part numbers printed on them.
   / LS Tractor Oil, Gas, & Air Filter Information #395
Just checked mine, same, nice! Dealer is seeing if LS will pay for the fuel filter as part of troubleshooting my regen issue, but doesn't think they will. I'll know next week, if not I'll grab the one you posted, it's $13 at the local auto store.
   / LS Tractor Oil, Gas, & Air Filter Information #396
Do we (who own LS tractors) need a sticky with oil, gas, air filter information?
I will add that from what I gather the following info is for the R4010:
Wix filter info:
Fuel Filter P/N 33128, Engine - Mitsubishi S4QL Engine
Oil Filter P/N 5106453, Engine - Mitsubishi S4QL Engine
Air Filter P/N 46438, Donaldson P/N P821575
WIX Filters : Filter Look-Up
Fleetguard:
Wix 46438 & Napa 6438 Air Filter: FleetFilter Secure Online Store
Napa 6438
NAPA Online
Fram Air CA9550:
Search Results
Gravely Air PP30055
Gravely 21537000 Replacement [PP30055 Grave] - $13.76 : 491588, Air Filters, Air Filters, Oil Filter for small engines
Fram Oil:
FRAM - Part Details
Also here is some info on the filter for other manufacturers models with the same engines etc. but youll have to do some cross referencing:
tractor_filters[1].pdf - File Shared from Box.net - Free Online File Storage
If you do want a Sticky - Lets contact a Moderator, like:
TractorByNet.com
Or if you know of one.
If not, so be it.
I have a 2018 XR4140 with the LS engine, not the Shibaura. But, yes, I'd love to see a sticky that cross references all the filters. It's been a bear finding published cross references, and my local NAPA was clueless.
   / LS Tractor Oil, Gas, & Air Filter Information #397
has anyone on here posted filter swaps and oils for Ls 3032
thanks
   / LS Tractor Oil, Gas, & Air Filter Information #398
Question on the "Water-in-Fuel" Sensor. How does it come off the bottom? Unscrew or just pull off?
I have spun it about 1/2 turn and can't really tell if it unscrews or not. My next move is to unplug the connector then try unscrewing it several turns.
Neither the owners manual or the service manual actually provide this information.
   / LS Tractor Oil, Gas, & Air Filter Information #399
Mine is a screw in. I'd assume yours is too. But I am not familiar with your model.
   / LS Tractor Oil, Gas, & Air Filter Information #400
I think mine is a plug. My tractor is am MT3 52 tho... looks about the same in your pic. Where did you get your service manual??
2014 TROXELL 130BBL VACUUM TRAILER (A52472)
2014 TROXELL...
Chevrolet C8500 Flat Bed with a Moffet Kit (A53472)
Chevrolet C8500...
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A53472)
FIRESTONE 9.5L-15...
2001 Ford F150 (A50121)
2001 Ford F150...
