LS s3010 starter fuse
/ LS s3010 starter fuse #1
hcastillo
greenville, tx
ls s3010
My tractor keeps blowing the starter fuse. The wires connecting to the fuse get hot when attempting to start the tractor and then the fuse blows.
/ LS s3010 starter fuse #3
did you ever figure out this issue?
These overheating wire situations are usually the result of a corroded connection, of the battery cable to the starter through the bstart relay and/or solenoid or a dirty ground connection of the battery negative cable to the engine or frame. Sometimes the mating surfaces of the starter and engine block get corroded and in doing so add resistance to the starter's needed ground.
Dave M7040
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
2007 KOMATSU PC35MR-2 TRACKED LOADER EXCAVATOR (A59914)
2007 KOMATSU...
2022 EZ-GO ELITE...
Landhonor Quick Attach Power Rake (A66285)
Landhonor Quick...
Snow Plow & Salt Spreader (A62613)
Snow Plow & Salt...
24in pin on excavator tooth bucket (A61307)
24in pin on...
