LS s3010 starter fuse
/ LS s3010 starter fuse #1
hcastillo
greenville, tx
ls s3010
My tractor keeps blowing the starter fuse. The wires connecting to the fuse get hot when attempting to start the tractor and then the fuse blows.
/ LS s3010 starter fuse #3
did you ever figure out this issue?
These overheating wire situations are usually the result of a corroded connection, of the battery cable to the starter through the bstart relay and/or solenoid or a dirty ground connection of the battery negative cable to the engine or frame. Sometimes the mating surfaces of the starter and engine block get corroded and in doing so add resistance to the starter's needed ground.
Dave M7040
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
Kubota SVL 97-2 Skid Steer (A65579)
Kubota SVL 97-2...
2022 EZ-GO ELITE...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
