LS R4041 vs XR4040
   / LS R4041 vs XR4040 #1
ThatServerGuy
Oxford,Ga
LS XR4145H
Looking at the LS tractors and wondering what the major differences are between the R and XR series tractors. Also pricing in Georgia for either?
Thanks!
   / LS R4041 vs XR4040 #2
Welcome to TBN..................
The R4041 has a Mitsubishi tier 4 interim engine, the XR4040 has a tier 4 Shibaura engine.
XR is the newer series tractor and probably has a few more options.
Both engines are very good. The XR has more emission controls than the R series but they are fully automatic and don't require user input.
I've had the XR3037HC model for over a year now and it's been a great tractor. Can't help with pricing as most all brands of tractors had a price increase since I bought mine. You check out the specs for both on the LStractor site.
   / LS R4041 vs XR4040 #3
XR has a few things moved around, like the loader joystick (more integrated), parking brake lever, fuel tank (behind the seat on the R, under the drivers side platform on the XR), decals & grill/headlight changes, little stuff like that.
Like mentioned, different engine with tighter emissions, slightly lower power ratings.
Biggest change is that the XR now comes with a cab option, which wasn't available in the R series.
   / LS R4041 vs XR4040 #4
Other than the details previously mentioned, the XR has a bit roomier operator's station.
I can't help with pricing near you, but around here an XR 4040H runs around $23,500. If you can find an R4041, I would expect it to be more like $21K.
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
UNUSED AGT SDA 140W WHEEL LOADER (A52706)
UNUSED AGT SDA...
TEST YOUR BID BUTTON! (A52705)
TEST YOUR BID...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
