LS R3039H oil change info needed
   / LS R3039H oil change info needed #1
RAYJAY
CLIFFORD PA
LS 3039H
Hi all can't find my books for tractor, how much oil does the 3039 take on a oil change and what filter is every one using, my former dealer does not handle LS anymore so, was going to use the Napa 1365 filter and rotella t 15w-40 for oil is this correct? IRC think its 6 quarts needed
thanks Jeff
   / LS R3039H oil change info needed #2
That is why I ALWAYS download a copy of all manuals to my computer for any equipment. That way I can get quick and easy answers by using the "FIND" search option. I can easily print out a page to use in the barn or elsewhere.
do that all the time LS does not have a free down load option for there manuals.
   / LS R3039H oil change info needed #4
Manual says 1.2 gallons (4.5L).
I use LS filters. But you should be able to cross it. If you can't get a cross to the tractor, try a cross to the Mitsubishi S4L2 engine.
RCO Tractor has the R3039 Operator Manual to download
   / LS R3039H oil change info needed #5
Oil/Filter change is 5 quarts. I'm using the LS filter --- 40056451.
thanks everyone, the LS tractor is awesome, there dealer/ manufacturer support is another story to tell ........
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
HAY SPEAR, 3PT (A58374)
HAY SPEAR, 3PT...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
405 (A52706)
405 (A52706)
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
