LS MT357 - AC Blower Issue
/ LS MT357 - AC Blower Issue #1
Macinnis
St. Louis/Old Mines MIssouri
LS MT3 57 Cab
125 hours or use, garage kept…runs like a top.
I greased everything up yesterday, blew out the radiator and went to work.
it was cool out, so it took a while for me to turn the ac on. When I did, I noticed it was on setting 1, but no air was blowing out of any vent. Moved to setting 2, still nothing, setting 3, nothing. Setting 4…air came out full blast and was COLD. I spent the next 5 hours cycling the ac from off to setting 4 and getting too cold too quick.
has anyone had this happened or have any clue what to look at to remedy this?
Thanks,
Bill
/ LS MT357 - AC Blower Issue #2
It's most likely either the fan switch it's self or there is a separate resistor for the fan speeds. When the resistor burns out or breaks often all that works is the high speed as it is direct wired and doesn't go thru the resistor.
/ LS MT357 - AC Blower Issue #3
Can adjust the temp to add in some warm then you can leave the AC running full with cold + warm to keep it comfortable without having to turn the fan off.
I do this in the winter when snow pushing - keeps the windows from condensating and I can see out all the windows.
Fan switch is the culprit as mentioned.
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
John Deere 4955 Tractor (A66285)
John Deere 4955...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
(2) Denman Tires w/Rims (A64127)
(2) Denman Tires...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
2022 EZ-GO ELITE...
