LS MT225 weird motor problem
/ LS MT225 weird motor problem #1
Mrsig
Platinum Member
Bushnell, Fl
LS MT225 4x4
Some times with a load or with out a load the motor will start making a weird revving sound and I will lose power. It happens on long or short jobs and last for 10 seconds to about 120 seconds. Any idea what it is? Fuel is clean and good. It has about 235 hours on her.
/ LS MT225 weird motor problem #2
What about the filters (air and fuel)?
I mention that because it's under 25hp and probably doesn't have the Eco Junk.
Checked the filter both good. No water in one and clean on other.
/ LS MT225 weird motor problem #4
Is the engine slowing down or speeding up when it is doing this? Does it do it at all engine speeds (idle, max, in-between)? Can you post a video of it?
I run it at 2000 Rpm Unless I am dealing with a big load than I run it at 2500 Rpm. It has done it at lower Rpm all so. I will try to get it on video. Thanks
My new dealer is about an hour away and my main rig is down and wife Jeep can't tow it so I hope you guys help me find the problem.
Thanks again.
/ LS MT225 weird motor problem #6
When tractor works hard after a while you can get motor issues..
/ LS MT225 weird motor problem #8
I have same unit at 227 hours, just put grapple on used it without issue. Since these tractors have an electronic throttle and also an electronic kill solenoid it could be either is going bad or connections are loose. Regardless you should have some warranty left for dealer to repair at no cost. If you have ruled out fuel and filter then it has to be something else. I have had in the past electric pto switch go bad causing no start on zero turn mower. I know there is circuit passes through for safety. Doubtful it’s your seat switch as the MT225S will start and run without occupant. Now it could be your safety switch on the seat, if no weight is on seat and hydrostatic drive is engaged tractor will die. Previous threads you mentioned backhoe on tractor meaning you have positional seat. Inspect switch check continuity disconnected this might be your issue. Regardless you have warranty coverage.
/ LS MT225 weird motor problem #9
I have the same 225s. It has had the same issue since new. Currently at 77 hours. LS had me check the engine speed sensor fir debris on its magnet. Not the issue. It's more prevalent in the cold for sure. I'm going to play with hydro oil levels, too as I topped it up after a steering cylinder repair and not got worse.
filled it from the bottom of the stick to the full mark.
About the end of January it stopped doing that and has been running great since.
/ LS MT225 weird motor problem #12
It just ceased? I wonder what was causing it? Change of temps with the season?
/ LS MT225 weird motor problem #13
I have a 225s and don't have that problem. Had it for a couple of years now, <than 300 hrs. Only problems I had was a left rear light assy where some LEDs were acting up....dealer replaced, and I modified the seat, removing the seat switch so that I could get off and on without the thing shutting off....a real PIA when you are hooking up implements, working alone, and my "simulated on the seat" mod needed some redoing...my problem, not the tractors.
/ LS MT225 weird motor problem #14
I must come under the wire only kill switch I have on my MT225S is if the hydrostatic engages without my bottom side on it the tractor dies. I can start unit without being on the seat. Same goes for pto switch unless you’re in the seat it dies. I am at 280 hours no issues except had to rebuild the mmm mower wheels. Mounted cage bearings on swivels and inserted steel bushings in plastic wheels. Lastly drilled the bolts through to add grease zerk for lubrication of steel bushings. Not planning on working on the wheels again for 300-500 hours. Has anyone changed out hydrostatic fluid needed to know if unit is self priming some require positive pressure to get oil to the pump.
2022 EZ-GO ELITE...
SDLanch SDLGC80 (A64127)
SDLanch SDLGC80...
JOHN DEERE Z515E ZTRACK ZERO TURN MOWER (A65054)
JOHN DEERE Z515E...
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A65643)
BG PF5 HIGH OUTPUT...
Stout Utility Grapple XHD84 (A66285)
Stout Utility...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
