LS MT125 Tractor First Minor Breakdown
   / LS MT125 Tractor First Minor Breakdown #2
Aircraft mechanic’s trick: Insert a piece of the largest diameter wire that will fit through the roll pin through it and twist the ends together on the outside of the shaft. That will prevent the pin from migrating again.
If you only have say .032” wire, you can get fancy and do a couple loops through and do a figure 8.
Dang! That is awesome. I have used safety wire all my career, but I have never seen it used like that. I will have to dig out my safety wire pliers. Thanks! We are never to old to learn.
   / LS MT125 Tractor First Minor Breakdown #4
In my 45 years as a professional mechanic I have never heard that trick. Ingenuous I would have to say about that idea. Thanks for that one.
   / LS MT125 Tractor First Minor Breakdown #5
As an aircraft electrician in USMC I used safety wire extensively and never saw or heard of this trick. Awesome!
   / LS MT125 Tractor First Minor Breakdown #6
Glad I could help.
The gears that drive fighter aircraft gun systems are often held onto a shaft with a roll pin and safety wired like that. I’ve never seen one migrate even after firing thousands of rounds.
TANK MANIFOLD (A55745)
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
Hyster H80FT 8,000LB Forklift (A56857)
Hyster H80FT...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
LOT: (17 approx. ) Rolls of Chain Link Fence (LENGTH UNKNOWN) (A59076)
LOT: (17 approx. )...
