LS MT125 Tractor First Minor Breakdown
   / LS MT125 Tractor First Minor Breakdown #2
Aircraft mechanic’s trick: Insert a piece of the largest diameter wire that will fit through the roll pin through it and twist the ends together on the outside of the shaft. That will prevent the pin from migrating again.
If you only have say .032” wire, you can get fancy and do a couple loops through and do a figure 8.
Dang! That is awesome. I have used safety wire all my career, but I have never seen it used like that. I will have to dig out my safety wire pliers. Thanks! We are never to old to learn.
   / LS MT125 Tractor First Minor Breakdown #4
In my 45 years as a professional mechanic I have never heard that trick. Ingenuous I would have to say about that idea. Thanks for that one.
   / LS MT125 Tractor First Minor Breakdown #5
As an aircraft electrician in USMC I used safety wire extensively and never saw or heard of this trick. Awesome!
   / LS MT125 Tractor First Minor Breakdown #6
Glad I could help.
The gears that drive fighter aircraft gun systems are often held onto a shaft with a roll pin and safety wired like that. I’ve never seen one migrate even after firing thousands of rounds.
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
Year: 2013 Make: Chevrolet Model: Caprice Vehicle Type: Passenger Car Mileage: 73,798 Plate: Body (A50324)
Year: 2013 Make...
KUBOTA KX033-4 EXCAVATOR (A51242)
KUBOTA KX033-4...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 84"...
