LS MT125 fuel tank leaking
   / LS MT125 fuel tank leaking #1
Alrock
LS MT125
I have a 2020 MT125 with that has a fuel leak, possibly the tank. I have the cowling, deck, and seat removed. I am about to remove the fenders that cover the tank. Any tips on removing the PTO speed knob and control handles? Anyone else experience a fuel leak on their MT125?
   / LS MT125 fuel tank leaking #2
There have been a few that had a defect in a molding seam when the tank was made, but that usually shows up in a short time after the tractor is purchased. If yours is a 2020 it would be odd for it to start leaking after this much time, but anything is possible. It could have a crack. I saw one that had a cotter pin on the mower deck lift linkage poke into the tank when the hitch and deck were raised all the way up. Check the fuel hose and clamp that are attached at the bottom of the tank also..
There is no pto speed knob, but the hitch drop speed knob and mower deck height adjuster knob have to be removed. The drop speed knob has a screw recessed in the center of it. The mower deck height knob has a roll pin through the shaft that has to be driven out with a hammer and punch. It helps to have someone hold a big hammer against the shaft so it doesn't just bounce while you drive out the pin. The rubber grips on the control levers can be hard to get off. I put the jaws of a needle nose pliers on the lever below the grip and pull up on the jaws and handle of the pliers at the same time like a T handle. They are usually stuck and hard to pull off if they have never been removed before.
Your reply is perfectly on point. I am planning on getting to tank this weekend. I appreciate your detailed response!
Tank was leaking just forward of the chassis mount. I just hope I can remember where all the parts and bolts go back!
Thanks again.
   / LS MT125 fuel tank leaking #4
My NH Workmaster 40 built by LS has a fuel tank leak also.170 hours on unit.
Sourcing a tank was PIA, but the local NH dealer was able to get one fairly quickly, but not cheaply! The LS dealer couldn't get one for several weeks and was priced more than the NH. 195 hours on the unit and stored in a shed.
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
UNUSED FUTURE 15" EXCAVATOR GRAPPLE (A51248)
UNUSED FUTURE 15"...
2013 CATERPILLAR CT660L SBA 6X4 ROAD TRACTOR (A51247)
2013 CATERPILLAR...
2014 CATERPILLAR 279D SKID STEER (A51246)
2014 CATERPILLAR...
