Item Details
- Type
- Tractor
My LS Backhoe Loader 4wd Mitsubishi Diesel engine Tractor has had all services kept up. Has just 170 hours with 2 years left of 1500 hour factory powertrain warranty. Asking$24k or best offer. text: six three six 492 one two three one
This is not a toy, it is the bigger XG series of Compact tractors.
I've been the only user/operator of this tractor and purchased it brand new for my own use, but I no longer need it. So save Thousands of Dollars over a new one, with all the options mine
has and get this gently-used low-hour unit that includes a protective steel canopy top as well as an optional post hole digger that operates off the 3 point hitch.
Plus it is my understanding that LS tractors have been made on the same assembly line as Mitsubishi, New Holland, Farmtrac, Tafe as well as Case-IH.
Here is info from online about my farm tractor:
LS XG series compact tractors feature a whole lot of power in a compact wrapper. Ideal for properties up to 10 acres, the XG3025 is capable of field mowing, clearing brush, building fences, cleaning barns, and just about any other chore.
LS tractors lead for their performance and durability, the sub-compact tractors deliver the power and adaptability you need for all your agricultural and landscape projects.
For those who require less maintenance and better output, LS tractors provide and deliver such models. You may go through the details of models here on this site which will help you to choose the right one for you.
Take on tough jobs and maximize your options with available front-end loaders, mid-mount mowers, and backhoes” all of which can be attached at the same time.
Mitsubishi diesel engine that’s fuel-efficient and very reliable. No DPF or reburn needed.
Engine Horsepower: 24.4
PTO Horsepower: 19.2
Transmission: 12 x 12 Shuttle
3pt Lift: 1,808 lb.
Loader Lift: 1,600 lb.
category 1 3pt hitch is compatible with most implements, giving you additional choices vs. limited Category 0 hitches on other brands.
The independent PTO (mid, rear or both) is turned on or off with a conveniently located knob. Independent PTO means the PTO shaft is turning regardless of ground speed or direction.
Power take-off (PTO) specs
PTO claimed power 17.1 hp 12.8 kW
PTO engine @RPM 540@2509 (rpm)
PTO clutch system wet disc
Rear PTO system independent
Rear PTO RPM 540 (rpm)
6 Year Power Train Warranty
LL3110: Quick Attach, Skid Steer Compatible Front End Loader with Grill Guard & 66" bucket
LB1106: 6' Quick Attach Backhoe with 9" bucket and optional 16" bucket
#Tractor #FarmTractor #FrontLoader #Backhoe #4WD #4X4 #DieselEngine #LS #LSTractor #Mitsubishi #NewHolland #CaseIH #FarmTrac #Tafe #Kubota #JohnDeere #SkidSteer #STL #StLouis #Missouri #Ballwin
3pt Lift: 1,808 lb.
