LS GX3032 Loader Control Issues
   / LS GX3032 Loader Control Issues #1
texascedar
South Central Texas
JD 850, LS J2023H
This unit is about 18 months old with 354 hrs. I use bucket, grapple rake and tree puller on the FEL.
Recent problem with the joystick cables coming unscrewed at the ball joints were fixed by dealer after 3 tries.
I go out today and the loader lifts, lowers, curls but will not roll the quick attach plated. The hoses to the front cylinders pressurize but only extend about 2 inches.
What are some causes for this problem?
Didn't see a delete button for this post.
Got my answer from another thread. Two months ago I had a new clutch installed. they had to remove the FEL. I didn't there were mid quick connectors as this is my 1st FEL and I never removed it. Guess when the dealer hooked it back up one of the connectors wasn't totally connected. Weird because I have used it for 9 hours since I got it back from the dealer. One thing, where the connectors are located there is a cluster of hoses and quick connectors that were bound together with a large nylon zip tie. Guess the pressure from the zip tie keep the connector from fully disconnecting until now.
Any way thanks to this forum I am back in business.
2014 Caterpillar 257D Compact Track Loader Skid Steer (A50322)
2014 Caterpillar...
2023 CATERPILLAR 307.5 EXCAVATOR (A51242)
2023 CATERPILLAR...
2015 CIMC 40FT CONTAINER CHASSIS (A52141)
2015 CIMC 40FT...
CATERPILLAR 315FL CR EXCAVATOR (A51242)
CATERPILLAR 315FL...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
