windcatcher
- Joined
- Mar 19, 2014
- Messages
- 281
- Location
- North Carolina
- Tractor
- Farmall Cub, John Deere 322 w/ scrape blade & 48" mower, JB JR bucket, Simplicity LandLord DLX, Haban 3 pt hitch Sickle bar Mower, Lemon LS XR3032H
Hi folks. Need some advice here please?
I'm thinking about purchasing a new G3033H TLB probably June of this year. I plan on using it to care (rotary mowing) for a pond area, pulling a plow, tending the wet area behind the pond dam, etc.
I want to plant sweet corn so plowing and cultivating is is a big need.
Do any of you have a G3033H or similar and have been using your tractor this way? What pros and cons do you have?
Also, I'm on the fence about either getting the Ag tires or the R4 Industrial tires. It is very wet around the pond, with many underground springs here and there. Traction is a must. I've seen where some of you are plowing with larger LS tractors and have the R4 tires. I've also seen where some had a whups! moment, and got your tractors stuck in spite of the R4 tires. I'm accustomed to a Farmall Cub with Ag tires, and I've yet to get stuck. Got close, but still not stuck.
I know, I know, this isn't even close to comparing apples to apples, but it's the best experience I can offer.
My thinking is: the ag tires will give me the traction I think I need. Plus they are a bit more narrow tire so that I can drop the up hill tires in the plow rut and follow the rut to continue plowing. Hopefully, they will be better for the wetter areas too, but something tells me the R4 would have more flotation for the wet areas, so I'm confused.
Opinions and actual experiences are definitely needed!
Thanks for your insight.
