LS G3033H questions
   / LS G3033H questions #1
BlaisePascal
Birmingham, AL
John Deere 5105
Hi,
I'm considering buying a 2014 LS G3033H with low hours. I've searched the forums and online, and I still have some questions:
1. Does it have a Tier 4 compliant engine?
2. Are there any known issues that I should check for, such as the jerky 3-pt on Kubota L series?
3. Can it handle a 6' rotary cutter? I'm sure a 5' would be a better fit, but I already have a 6'.
I'll ask a question about the price in the Buying forum.
Thanks!
   / LS G3033H questions #2
Hi,
Thanks!
#1 No my 16 3025 is teir 3
#2 if you order parts the Koreans us as you face the tractor for lt or rt. Check all the clamps and fittings
# 3 theres is reccommended vs what you can actually do.
   / LS G3033H questions #3
my 2018 is a tier 4, but if it's the regen stuff he's worried about, that goes by kilowatts, which is then translated to HP. I'm wondering what the HP rating for that 3033 is? 33? I believe anything over 25 is required to regen or have the extra 'catalytic' converter type of exhaust. One of the main reasons (besides only owning a couple of acres) I stayed with the 25 HP
as for pulling the bush hog, I know my whole life I was always told 5 PTO hp per foot of bush hog. That seems to really not matter as much with the electronically controlled PTO now. I run a 5 ft with my 24.4 hp tractor with 19.2 hp PTO. If that 3033 is 30 or 33 hp, OP shouldn't have any trouble with a 6'
   / LS G3033H questions #4
30 is the class the last 2 are horsepower.
   / LS G3033H questions #5
As there is a drop in horsepower to the PTO, it is an H, I think it will run the 6 foot but 5 would work a lot better. Would not want to put in 5 foot grass.
I got my LS, south of you in Columbiana. They sale, service and sale parts for the LS.
   / LS G3033H questions #6
I bought my at Haney equipment up in Athens close to Huntsville ut live in Thomaston Ga about an hour northwest of of the stateline
   / LS G3033H questions #7
The G30XX series tractors are tier 2. There never were any tier 3 engines below 75 hp (source is EPA website) unless the manufacturer used some of the obscure options available under the regulations. These tractors have no computer or exhaust after treatment.
Your 3025 is not listed on Tractor Data so I don't know which engine it has. Does it have exhaust after treatment?
The PTO hp on the G3033 is 26hp. A little under the recommended 5 hp per foot of implement but I'd go ahead and run your 6 foot implement and see how it does.
   / LS G3033H questions #8
I thought it was tier 3 no cat, no deg, no regen. Tier 2 Tier 3 dont care just glad none of that crap. A 3025 is same as a 3033 just a 25 hp motor
   / LS G3033H questions #10
mine has the tier 4 mitsubishi S3L2 engine. No after exhaust emissions stuff. I'm sure at one time, his '30xx are tier 2' statement is correct, but as the regs changed over the last few years, so did the engines.
if he's saying there's no computer, then they must have physically done something to these to make them under 25 hp, and I'm very curious as to what that might be ;) piston size? valves? fuel injection?
as per the '5hp per ft' rule, by that, at 19.2 PTO hp, I wouldn't be able to run the 5 ft bush hog I have, but I've put probably half the hours on my tractor bush hogging, and most of it was chest high or there abouts. If he's 26 PTO hp, and it's the electronically controlled PTO, he should be able to run that 6'. now since he said this was a 3033H, the hydrostatic drive units typically have a few less PTO hp.....
   / LS G3033H questions #13
I tried twice to upload the engine service manual. Do a search on Mitsubishi S3L. It that is the engine you have
   / LS G3033H questions #14
Hi,
Thanks!
That is a LS L3BL and 117 cub inch engine 33 HP and 27 PTO and yes it could pull a 6 ft clipper but 5 ft would be a better fit, i used a Mahindra 3016 (Mitsubishi 80.4 CI Engine ) 28 hp 23HP PTO to pull a 6 finish mower with no problem but did need to be in 4 wheel drive most of the time now with the XG3135 i cut in 2WD 35HP 114.7 CI PTO 30HP Turbo engine
   / LS G3033H questions #15
That 2014 is a good one to have. Very reliable and no regens! I have a 2014 G3038 and it has been great.
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
(10) 10'-6" PVC CONDUIT PIPES (A60432)
(10) 10'-6" PVC...
2439 (A60432)
2439 (A60432)
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
