LS G3033H questions
   / LS G3033H questions #13
I tried twice to upload the engine service manual. Do a search on Mitsubishi S3L. It that is the engine you have
   / LS G3033H questions #14
Hi,
I'm considering buying a 2014 LS G3033H with low hours. I've searched the forums and online, and I still have some questions:
1. Does it have a Tier 4 compliant engine?
2. Are there any known issues that I should check for, such as the jerky 3-pt on Kubota L series?
3. Can it handle a 6' rotary cutter? I'm sure a 5' would be a better fit, but I already have a 6'.
I'll ask a question about the price in the Buying forum.
Thanks!
That is a LS L3BL and 117 cub inch engine 33 HP and 27 PTO and yes it could pull a 6 ft clipper but 5 ft would be a better fit, i used a Mahindra 3016 (Mitsubishi 80.4 CI Engine ) 28 hp 23HP PTO to pull a 6 finish mower with no problem but did need to be in 4 wheel drive most of the time now with the XG3135 i cut in 2WD 35HP 114.7 CI PTO 30HP Turbo engine
   / LS G3033H questions #15
That 2014 is a good one to have. Very reliable and no regens! I have a 2014 G3038 and it has been great.
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
Pat's QH and hydraulic top-link.
Pat's QH and...
