Oil & Fuel LS G3033H How to check front axle oil?
   / LS G3033H How to check front axle oil? #1
AUSTENNN10
Alto nm
Ls 3033
Ok the manual is no help and I searched and found nothing so....My 3033 front axle has a blue plastic cap on the top of the right front axle, remove that and I can see oil way down there. There is no dipstick. How do you tell if its low?
On the left side is a big white paint bolt head. I did not remove it but its on tight.
Any thoughts?
   / LS G3033H How to check front axle oil? #2
Its on the left side, dont ask how i know :D
Any thoughts?
Screw dipstick in or not?
   / LS G3033H How to check front axle oil? #4
I do, not sure if that's right, I would rather have a little more than not enough. Like you said the manual is no help. I had to ask my dealer how to check it, I thought for sure it would have been under the blue cap.
I think if you screw it you could overstate not understate. Not screwing would give the lesser value.
   / LS G3033H How to check front axle oil? #6
Huh I was just looking at this today. I took the blue cap off on right side of front axle and thought huh where is the dip stick talked about in the manual? So I called my dealer and he said its the blue cap and I said well there is no dip stick. He thought it might have broken off? Or there was a fill drain plug towards the top near the blue cap that I took out. Well now I know where its at and will let me dealer know since he is a brand new dealer up here in Alaska.
Thanks azranger
   / LS G3033H How to check front axle oil? #7
Any thoughts?
The dipstick is the bolt painted white on opposite side of blue oil fill cap
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
2001 Freightliner MB55 Chassis Bus (A56858)
2001 Freightliner...
48 Volt Club Cart 4-Seater (A56859)
48 Volt Club Cart...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
