LS G3033 Forward Shuttle won't Stay engaged...
   / LS G3033 Forward Shuttle won't Stay engaged... #11
You will need to split the tractor between the engine and clutch housing and remove the front transmission cover. The forward / reverse synchro is on the input shaft behind the front cover. You shouldn't need to remove the whole transmission unless you find more wrong. Investing in a service manual will make life easier. $125 manual will save a lot versus paying a repair shop. I split mine in the shed with a rolling floor jack and jackstands. Drive some wooden wedges between the front axle and side frames before rolling it apart to keep the front half from tipping. Don't forget to remove the detent ball and spring before removing the F/R shift rail after you take off the transmission front cover. Guess how I know this.
Yes sir, I thank you for your help. Everyone has been helpful with this and I cannot thank you all enough. I understand the ( Guess How I Know This) part. LOL God bless and thank you again!!!!
How did it turn out? Mine has started doing this
I'm sorry, I did not get notified you had asked a question. Still have not done anything with my tractor and baby it when I do use it lightly. I have been told to split the tractor and it is probably the F/N/R syncro gear may be the culprit. But I will post again when I get mine looked at and fixed. Thank you and I'm sorry for being so late in answering you. But split the tractor at the clutch area and pull the front cover off the transmission to start.
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
CFG Industry MX15RX Mini Excavator (A57149)
CFG Industry...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A57453)
2007 International...
