LS Error Code
/ LS Error Code #1
gnbennett
LS MT342
Thanks in advance for any help.
LS MT342 Tractor
After operating for 5 - 10 minutes, the tractor goes to idle speed.
Red exclamation light is on.
Error code F02 636 is on.
Suggestions?
/ LS Error Code #2
Crankshaft sensor.
/ LS Error Code #3
I got that error too. My MT342H started with that one, then saw a 5202 F11 code not long after. The wiring harness was for the wrong tractor. However, that didn’t fix it. I posted on a thread here by another member titled “issue already”. Look there. We both had the same error. His was fixed, mine not.
/ LS Error Code
Thanks for the responses. I've got the dealer lined up to check it tomorrow. I'll let you know the outcome.
/ LS Error Code
Not yet. Just got it there a few days ago, going to let him do my 50 hour service work too. Looking for it soon and I'll keep you posted.
/ LS Error Code
Repaired and back home. No problems, covered under warranty. A seal at the turbo was leaking allowing oil into the exhaust system, creating the code.
Let them do the 50 hour service as well. Very pleased with the prices and turn around time. Great attitude from the dealer.
The only thing they couldn't do is replace the HST filter, said it was on back order, scheduled to be in next week. Said they would come out and install it when it came in.
/ LS Error Code #8
I'm having this same issue. The 636 f02 happened, then it flashed the
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2014 CASE 580N BACKHOE (A65053)
2014 CASE 580N...
Multipurpose Skid Steer Mount Backing Plate  (A62679)
Multipurpose Skid...
2020 International LT625 48" Sleeper (A62613)
2020 International...
1999 Ford F800 Dump Truck, VIN # 3FEXF8019XMA05457 (A65563)
1999 Ford F800...
