Ls engine issue?
   / Ls engine issue? #1
Bbc396
Bronze Member
Nb, canada
Ls xr3135
So I was at my dealer this morning trying to swing a deal on a new snowblower and I wondered over to the service department and noticed that Thay had a xr4140 that Thay were changing the engine in. Owning a 3135 I was concerned because Thay use the same engine. I asked the mechanic about it and he said Thay have a oil problem and this was the 7th engine that he has changed. Anyone have any engine issues with the xr series of tractors?
   / Ls engine issue? #2
Wonder what they say the oil problem is. Honestly this is the first I've heard of that.
   / Ls engine issue?
First thing I did when I got home was Google it and nothing came up. I would think if it were really a serious problem it would be all over the Internet..... the mechanic said he has done 7 to date but I know the one Thay had thare today was full of metal in the oil like a bearing failure. And it had 172 hours on it
   / Ls engine issue? #4
It would be helpful if you would add your location to your profile.
   / Ls engine issue?
New brunswick canada just curious why you needed to know?
   / Ls engine issue? #6
Some people seem to enjoy stopping by for tea and crumpets.
In this case, maybe it's a regional issue? Bad batch of engines to one area? Altitude, temperature or other climate factors? Like you said, this would be all over the web if it was widespread.
   / Ls engine issue? #7
Maybe somebody should tell the Dealer to put oil in them before they send them out the door :scratchchin:
   / Ls engine issue? #8
I did hear that it is very important that you follow the oil spec that is specified for this motor ... thinking that oil barrel of 15W40 that you kept for your other tractors will be fine will cost you. Apparently the little turbo will starve and then go boom - sometimes taking other engine parts with it. But that is just what I think I heard (being a senior my hearing is not always the best) from an LS mechanic.
   / Ls engine issue? #9
You can't run a Turbo-Diesel all day long at peak power then turn it off real quick to go have lunch. You can't even run them for an extended period at power and turn them off abruptly.
Those Turbos get hot. Real hot. Really, really hot. And when you cut off the air-flow that they get while running, they'll cook themselves. You need to let them idle for anywhere from 30 seconds to 5 five minutes, depending on how heat-soaked they are. Most of the time, just a few seconds if you haven't used the turbo much.
It also helps if you run something other than that old generic 15w-40 left over from your 1974 JD that's in the corner of the barn.
These new engines from LS are state-of-the-art engines. And they require more care and more knowledge than the old indirect injection diesels. Clearances are tighter, machining is far superior..... So many improvements and differences.
Would I be surprised to find there is a learning curve in these engines and there might be some things that need corrected/fixed? No, I would not.
But 7 engines in one dealer's repair shop?
I don't think so. Maybe more like, the mechanic has tried 7 times to fix the same engine. I'd buy that one.
I think the mechanic was funnin' the OP.
If 7 engines went back to a dealer, ANY dealer anywhere, the factory would shut down production until they tracked down the problem.
I've heard ducks fart underwater before.
   / Ls engine issue? #10
I have a feeling these engines come from the factory with a 15-40 Dino oil to help things break in. I can see how if new owner fired up their new tractors in sub zero temps and immediately revved it up to PTO speed, that it would definitely destroy an engine in short order.
My manual specifically says that when starting below 14F (or -10C) that 5W-30 is required. A northern climate dealership should not be selling tractors without first changing the oil to a 5W-30 as recommended in the owners manual.
There is recent story about a runaway engine where is sounds like the seal in the turbo blew out. I don’t think it is coincidental that it happened during the worst cold snap in decades.
Edit: this is the most compelling reason I can think of to switch to a 5W-40 synthetic oil.
2016 Ford Escape SE AWD SUV (A50324)
2016 Ford Escape...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
2017 Chevrolet Malibu (A50324)
2017 Chevrolet...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
Vermeer 554XL Round Baler (A50774)
Vermeer 554XL...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
