LS Backhoe LB2105 VS 3104 Thoughts
   / LS Backhoe LB2105 VS 3104 Thoughts #1
SuperDan
Naples, Florida
LS XR4140
Considering the XR4041H which can accept the LB2105 or LB3104. Any thoughts on these two Backhoes?
   / LS Backhoe LB2105 VS 3104 Thoughts #2
I got the 3102 on my XU6168. Very happy so far. It’s very solid with the subframe mount. It will pick up the rear of the tractor with loaded rear tires without breaking a sweat.
   / LS Backhoe LB2105 VS 3104 Thoughts #3
You’ll need to buy or make some feet for the stabilizers. LS doesn’t provide them or even sell them last I checked. There are a few threads on where to acquire them though.
   / LS Backhoe LB2105 VS 3104 Thoughts #4
My tractor originally came with a LB2105. I thought it was pretty wimpy. I had originally asked the dealer for the larger backhoe, but was told it wasn't available for my model. I was so dissatisfied with the LB2105, I contacted LS tractor directly to ask about the bigger option and was told it was available. The brochure only lists the smaller option, but the LS website showed the two choices. The dealer agreed to swap out the backhoes for the difference in price, $800 more for an LB3104. I think the smaller backhoe would be fine where you have normal dirt. In the Rocky Mountains, not so much. I'm much happier with the LB3104 and definitely noticed a difference in power.
One caveat, due to an engineering design flaw, the LB3104 seat hit the rear window of my cab. I had to move it forward by two mounting holes to clear the cab window, but now the leg room is minimal. If you don't have a cab, it shouldn't be a problem.
   / LS Backhoe LB2105 VS 3104 Thoughts #5
I bought the 3104 and don't regret it! You will forget about the extra money quickly.
2023 CATERPILLAR 259D3 SKID STEER (A52709)
2023 CATERPILLAR...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
Service Truck Hydraulic Rear Liftgate (A55787)
Service Truck...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A57453)
(1) HD 27ft x 24ft...
2013 John Deere 350G LC Hydraulic Excavator (A56857)
2013 John Deere...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
