LS 4330 FRONT AXLE SEAL Need diagram
   / LS 4330 FRONT AXLE SEAL Need diagram
Just a not parts should be here tomorow.
The bearing was I think actually broken after the loss of fluid and then driving it back to the shed.
When I was talking about moving the tractor around with the backhoe: I was really putting not only the weight of the tractor high into the air, but also using the hydralics to push the tractor forward or back. Sometimes in mud and against tree parts etc..
I promise to change the oil and be nicer to my tractor!
Got the parts and proceeded with job. Unfortunately I only ordered one of the half moon keepers. I didn't notice you had to order two since they were the same part number. I tried to use one of the old ones.....NO LUCK getting the gear to slip over the keepers. I am headed 40 miles to Kubota dealer in Mims Fl who says they have them in stock. Local dealer in Orlando didn't have any. The saga continues.
JOB DONE "Nothing makes a man Happier than to get his tractor back!"
The old keeper was sprung just enough to keep large gear from going onto shaft completely. New keepers and it slipped right on. I then tapped the new inner bearing I picked up at the dealer on spline and tapped it on with rubber hammer. Slipped whole unit together tightened it up added about 6 quarts of fluid until it was weeping out plug hole.
Went to work with tractor will try and change the oil later HHAHAHAHAHAH
Thanks to all who helped me get back on the farm!
FYI the bearings and keepers were about 1/2 price than what I got online. Bearing was $16.00. A 3" schedule 40 pvc was perfect to tap on bearings and remove old one.
   / LS 4330 FRONT AXLE SEAL Need diagram #24
As a bit of info for those buying bearings in Canada:
for an L5030,
The lower stub axle bearing that the lower pinion sits inside is a TMB 209.
The outer wheel bearing is a Koyo 6209 C3
The inner wheel bearing is a Koyo 6208
2004 KENWORTH DIGGER TRUCK (A50854)
2004 KENWORTH...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2018 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2016 Ford F-450...
