LS 4041 HS Steering Problem with Load on forks
   / LS 4041 HS Steering Problem with Load on forks #1
SpaceBuckaroo
Keokuk, Iowa
LS
Hi,
I've owned a LS 4041 HS for a couple years. One problem that I've had since it was new is that when I have a load on the forks, the steering does not want to work well. The steering wheel will turn but the actual wheels will not, unless the tractor is moving in a forward or backward direction. This causes a serious problem when I'm trying to move a load through tight spaces.
   / LS 4041 HS Steering Problem with Load on forks #2
Sounds like the fluid may be low or the pump is going into bypass due to the weight on front axle. I assume it doesn't do this with light or no load?
   / LS 4041 HS Steering Problem with Load on forks #3
Whats on the rear for ballast?
   / LS 4041 HS Steering Problem with Load on forks #4
Hi,
Welcome to hydrostatic steering. Your steering wheel has no direct connection the the front wheels like power assisted steering in a car does. Sucks.
   / LS 4041 HS Steering Problem with Load on forks #5
GX3032 - my tractor does the same thing. It's bad on asphalt. It pulls to the right so much so that when I correct by turning the steering wheel counter clockwise over about 6 hundred yards the steering wheel has made a complete revolution.
At my 50 hour service the dealer replaced the power steering cylinder as being weak. Got it home and still does it just not as bad. It a real pain in the butt.
   / LS 4041 HS Steering Problem with Load on forks #6
Agree with kennyd. You need more rear ballast. too much weight on the forks (or bucket) without enough rear ballast will cause this problem. I've seen it on a bunch of tractors with hydraulic steering.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
TANK MANIFOLD (A55745)
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
