LS 3025H Right Brake Sticking.
   / LS 3025H Right Brake Sticking. #1
ehinson
Culleoka, TN
XG3025H
Tractor wasn't used much this year and now the right brake is sticking, I can pull the pedal up to release it but has anyone experienced this and or have a fix?
I lifted the arm so the pedals can move independently, tried driving it around some, tried forward and reverse while pressing and releasing the brake.
Still sticking.
   / LS 3025H Right Brake Sticking. #2
Have you tried crawling under the tractor and check for grease fittings on the pivot shaft that goes into the transmission housing to actuate the brakes inside? Some tractors have them, others don't. If it doesn't, you can also try spraying some sort of penetrating oil in the area.
I know I greased it before but I will check, I will remove the lever to determine if it's external or internal after that I guess.
Just wanted to know if anyone experienced this before.
ROME AH-240 LOT NUMBER 130 (A53084)
ROME AH-240 LOT...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A53472)
2009 Ford F-650 24...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A52576)
2005 PETERBILT 357...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
