LS 3025H Right Brake Sticking.
   / LS 3025H Right Brake Sticking. #1
ehinson
Bronze Member
Culleoka, TN
XG3025H
Tractor wasn't used much this year and now the right brake is sticking, I can pull the pedal up to release it but has anyone experienced this and or have a fix?
I lifted the arm so the pedals can move independently, tried driving it around some, tried forward and reverse while pressing and releasing the brake.
Still sticking.
   / LS 3025H Right Brake Sticking. #2
Have you tried crawling under the tractor and check for grease fittings on the pivot shaft that goes into the transmission housing to actuate the brakes inside? Some tractors have them, others don't. If it doesn't, you can also try spraying some sort of penetrating oil in the area.
I know I greased it before but I will check, I will remove the lever to determine if it's external or internal after that I guess.
Just wanted to know if anyone experienced this before.
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
