LS 225E Instrument Cluster Not Working
   / LS 225E Instrument Cluster Not Working #1
ChuluTrac
Chuluota, FL
LS M225HE
I have a 2 year old LS 225HE and today the instrument cluster stopped working. No RPM, Hours and both gauges were at zero. Everything else worked fine on the tractor. I called Bruno's tractor, where I bought it, and the tech suggested that I look at the ground on the firewall. Sure enough, that was the problem. The paint had not been removed under the ground wires, so I sanded it off, reinstalled the ground wires and put some grease on it. Problem solved.
   / LS 225E Instrument Cluster Not Working #2
Might want to do the same to the Engine ground, follow the Negative cable from the battery to where it connects to the tractor/Engine.
Seems this a common problem and not just on LS tractors.
2016 John Deere 6110M Utility Tractor (A50657)
2016 John Deere...
1261 (A50490)
1261 (A50490)
71057 (A49346)
71057 (A49346)
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
