LS 2025h tractor
/ LS 2025h tractor #1
Ericredslslingshot
Windham Maine
Ls xj2025h
The hour meter, gas gauge and coolant gauge do not work. Everything else runs and works. Checked fuses and all look fine. Any idea's?
/ LS 2025h tractor #2
In the manual the only correlation between the 3 is the instrument panel itself or a chassis ground.
/ LS 2025h tractor #4
I don't know LS but "back in the day" some of the instruments did not power directly from twelve volts. There was a lower voltage regulator (think five or six volts) in line to feed instruments. It may be part of the instrument panel and not shown as a separate component.
/ LS 2025h tractor
Thanks for reply. I think it's the panel also. Trying new fuse and if that doesn't work it will be time to call for service.
/ LS 2025h tractor #6
Let us know what you find out.
/ LS 2025h tractor
/ LS 2025h tractor
Ok, put in new 10amp fuse. Turned on key and gas and rpm meter still did not work. Turned on heado8ghts and flashers. All of a sudden gauges worked. Turned everything off. Turned key to on and gauges worked. Thank God I didn't gave to call service.
/ LS 2025h tractor #11
Good deal. You thinking a loose connection or rather a contact in the switch itself?
/ LS 2025h tractor
Well not do much. Went out this morning and it turns over but will not start. Only 80hrs on it although it's 3 years old. Could it be the seat safety switch?
/ LS 2025h tractor #13
I wouldn't think so. Maybe a drive position switch. I can always start mine off the seat, but touch a drive pedal it dies because the seat is unoccupied. You didn't really say, but you've had this running after fuse replacement- correct?
If I've ever had a no crank, it goes back to the PTO switch that got bumped.
/ LS 2025h tractor
Guess I'll go over and see dealer tomorrow. Hate to do it but I am not an electronic person.
/ LS 2025h tractor #15
You will see the switch for the drive pedals underneath the body near the pedals if'n you want to have a look. Cycle the PTO switch. Maybe you will luck out,
2019 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 MACK ANTHEM...
John Deere 5090GN (A60462)
John Deere 5090GN...
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A61574)
2018 Freightliner...
BUSHHOG 3414-14' HEAVY DUTY ROTARY MOWER (A64280)
BUSHHOG 3414-14'...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
