LS 2023H Muffler fell off
   / LS 2023H Muffler fell off #1
texascedar
South Central Texas
JD 850, LS J2023H
I have 60 hours on my new LS2023H and the muffler is cracked just above the manafold mounting flange. It is nearly broken all the way around.
The only thing i can figure is the bracket that secures the exhaust pipe is not aligned so that when tightened the setup is torqued so much it creates the stress crack.
Anyone experiemce this problem?
   / LS 2023H Muffler fell off #2
dealer told me to keep an eye on it as it is a known issue.
So far no cracks on mine 350 hours.
   / LS 2023H Muffler fell off #3
Happened to me. Check where the muffler bolts to the power steering pump. The bolt came loose on mine. You can either have them replace it or weld it. I did the later, works fine.
   / LS 2023H Muffler fell off #4
Muffler cracked on mine right after I bought it. Noticed it when the motor started to roar instead of purr. Dealer fixed it under warranty. Use your warranty, that's what it's for.
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
Zimmerman 6 Lug Running Gear (A50774)
Zimmerman 6 Lug...
Bobcat 30C Skidloader PHD (A50774)
Bobcat 30C...
2012 Chevrolet Cruze LS Sedan (A50324)
2012 Chevrolet...
KSI Conveyor (A52748)
HYDRAULIC SKID (A52472)
HYDRAULIC SKID...
