NoTrespassing
Elite Member
Hi All,
Being the cheapskate I am, today I pulled an old Sunbeam grill out of the weeds and decided to try to get it working instead of buying a new one. It had been sitting for years and still had a full tank of gas with it (old style). The regulator was shot and leaked gas out the side of it.
I went to the local box store and bought what I thought was the right regulator. It's a Mr. Heater brand regulator 1/2 PSI output, 75,000 btu capacity. I didn't want to buy a new style grill regulator since it wouldn't fit my old tank, and I noticed the regulator I did buy will fit the new style tanks when my old one runs out.
I cleaned up the burner and blew it out with compressed air. I hooked the tank up and lit it. It burned a nice blue flame all around the burner. I put in some fresh lava rocks and put the grill on and lit it again. Now here's the problem.
The grill doesn't heat up enough. Max temp on the grill surface is about 250 F. and it drops rapidly when opened. My question is: Did I buy too small of a regulator? And if I did, what size do I need? This one says it's for portable heaters, hot plates, camp stoves and other low pressure propane appliances that are 75,000 btu or less.
Any help will be appreciated,
Kevin
Kevin
