LP Gas tank problem
   / LP Gas tank problem #1
randy41
Veteran Member
Linden VA
the valve on the tank thats hooked up to my grill is very stiff. Is there a way to fix that? Would squirting some WD40 down the shaft be ok to do? the tank is kinda full. should i wait until its empty to try to fix it?
   / LP Gas tank problem #2
Wait until it's empty and bring it to on of those tank exchange places. They take almost anything, even the old style tanks as they replace everything anyway. Just for liability purposes. That's why they're so expensive.
   / LP Gas tank problem #3
I would not use WD-40 unless it's wet! But a little BreaK-Free CLP down the valve stem wouldn't hurt anything at all, and it may help.
How old is the tank? I'm assuming it's one you own rather than an exchange unit.
   / LP Gas tank problem #4
Open and close it a few times. It may loosen up the packing.:D :D
   / LP Gas tank problem #5
i can't see what harm spraying wd-40 on the thing will do: give it a shot.
heehaw
   / LP Gas tank problem #6
The valve may have a packing gland that is too tight but if you are not familiar with how these work they are best left alone.:D :D
Especially with a full tank!:D :D
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A55787)
2018 Bobcat T590...
(INOP) JOHN DEERE 317G SKID STEER (A52705)
(INOP) JOHN DEERE...
2008 Sterling Bullet Utility Truck, VIN # 3F6WK76A88G352277 (A54865)
2008 Sterling...
