California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,939
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
This is my first diesel and I'm trying to learn an 'ear' for proper operation. Warming up at 1800 rpm sounds smooth, but below 1600 cold the diesel knock seems excessive. Even warm, below 1200 rpm it sounds like if it were a gas engine it would immediately ping a hole in a piston. (A stethoscope shows this clatter focused at the injectors, not in the lower end!)
The owner's manual advises warmup at 1500 rpm then slow idle 800 rpm; working speed 1800 to 2400 rpm.
This doesn't sound good to my inexperienced ear. I know its a compression ignition engine but the 1500 rpm warmup and any operation below 1200 rpm, even just idling, has extreme diesel knock.
However the unit is 25 years old and still in great original condition so far as I can see, so it must be designed to withstand its recommended use ???
I would appreciate any advice you experienced operators can share. I've looked around and I see advice on injector pattern, premium 'designer' fuel to match Japanese fuel standards, and advice to simply ignore the racket - 'they all do that'.
Comments? Thanks!
Comments? Thanks!
