Lowering detent pressure on SCV on M7040
   / Lowering detent pressure on SCV on M7040 #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
Anyone know how to lower detent pressure on M7040 scv short of removing detent balls?? What is purpose of set screw on opposite end of spool that cable attaches to a cab tractor?
Thanks,Jim
   / Lowering detent pressure on SCV on M7040 #2
I got some of the same issues.
I think some of the issues is with the cables. I have it on my list to lube them, and not quite sure how to do that either.
   / Lowering detent pressure on SCV on M7040 #3
Softer spring in detent will probably do it. Can you post a pic of the set screw & spool valve?
:wrench:
   / Lowering detent pressure on SCV on M7040 #4
Same thing here. Curious to see if there's a fix.
:wrench:
Here's a copy of scv parts schematic set screw I'm referring to is key 180.
   / Lowering detent pressure on SCV on M7040 #6
I'm not familiar with that valve but it looks like a limit-stop screw to limit the movement of the internal component.
If you mark it you could try and back it off half a turn and see. Always can put it back to original position if it doesn't help your problem.
:wrench:
I backed set screw out 2 full turns & lowered detent pressure. Now scv lever is easier for me to operate. I baled 64 rd bales yesterday.
   / Lowering detent pressure on SCV on M7040 #8
Well there ya go!
:thumbsup:
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
2005 Blue Bird BB Conventional Bus, VIN # 1BAKBCKA45F219634 (A51572)
2005 Blue Bird BB...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2013 FOREST RIVER (A52472)
2013 FOREST RIVER...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
