Lower pivot pin sticking on BH77 with thumb
   / Lower pivot pin sticking on BH77 with thumb #1
jim_wilson
Northeast MA
Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
Has anybody found a greasable pivot pin that will fit in the lower pivot for the thumb on a BH77 with the factory thumb?
I just went to use my thumb today, after not having used it for a good year and a half - and the thing seemed like it was welded in place.
After finally beating it open with a 5 pound sledge and a piece of wood ( so I wasn't hitting metal on metal) - what I finally found was that the lower pivot (the one where the locking bar attaches to the thumb) - was pretty much rusted up bad enough that it was sticking the thumb in place. I've got the pin out and I 'm going to grease it up good before reinstalling - but what I would really like to put in there - is a greasable pin.
Looking at the factory parts blowup on the Kubota site - and it doesn't look like the one they supply comes with a grease zerk. Anybody swapped one in that has the grease zerk?
I'd like to avoid this happening again. The pic below has a yellow arrow pointing to the pin I'm referring to.
425129-lower-pivot-pin-sticking-bh77-bh77-thumb-jpg
   / Lower pivot pin sticking on BH77 with thumb #2
One possibility is to have one made at a machine shop,shouldn't cost too much.Or maybe you could drill and tap the outside piece to accept a grease zerk.
   / Lower pivot pin sticking on BH77 with thumb #3
Find some boat trailer wheel bearing grease. It's water proof and will last much longer in the field. Grease is basically oil suspended in a thickening carrier substance. Some grease uses a carrier that is very similar to soap and thus when exposed to water it will get washed away. Once the carrier is washed away the oil will quickly disappear.
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2014 Doyle Dry...
