lower hyd pressure
   / lower hyd pressure #1
GaryK
NC
JD 4100 HST
As most everyone did, I changed the hyd oil in my 4100 to the newer low viscosity oil from JD. I noticed that the lifting power has diminished on the FEL and this coincided with the change in hyd oil. Has anyone else noticed this and how much of a hassle is it to boost the output of the pump? From what I have read, it requires a shim or two.
Jeff, thanks, I knew I saw a post on this a while ago. the hyd tester looks easy enough to make up.
2023 Kubota L2501D 25HP 4WD Utility Loader Tractor (A50322)
2023 Kubota L2501D...
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
2006 Volvo VNL (A52748)
2006 Volvo VNL...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
