Lower Back Brace Worth Recommending?
   / Lower Back Brace Worth Recommending? #1
dalola
Platinum Member
Ohio
Kubota BX2380 w/FEL, Woods RM48, Yazoo/Kees Max2 ZTR
Looking on Amazon, all the choices are rather overwhelming!
Anyone with a positive experience worth sharing?
Just looking for extra support for my lower back when working, to help avoid some of the pain that comes after a day of working/lifting/etc..
   / Lower Back Brace Worth Recommending? #2
I use a back brace called "Back thing" made by R.U. outside. I only use it when doing work the requires lots of lifting or bending over, and riding my snowmobile. I highly recommend using something similar. It makes a big difference later on after the work or fun is over. :thumbsup:
   / Lower Back Brace Worth Recommending? #3
My lumbar salvation has been certain yogo/McKenzie/philates activities. The Little Cobra is noteworthy! AKA McKenzie #3. JUST DO IT!, you'll be glad I told you so. I do currently use a knee sleeve bought on Amazon as my knee is getting close to replacement-maybe? Strengthening the back is the better approach. My lumbar report is 3 pages long.
   / Lower Back Brace Worth Recommending? #4
Lifting belts were all the rage for awhile. Guys riding motorcycles used to wear kidney belts for added back support. In the long run I'll agree the best solution is doing some exercises to strengthen the lower back.
   / Lower Back Brace Worth Recommending? #5
Go to a chiropractor, get the x-rays and a tune-up. Go to the follow up visits and do the recommended stretches.
It works.
And do about 40 squats every morning.
   / Lower Back Brace Worth Recommending? #6
It works.
I needed an operation as after the 3rd visit I was in tears before AND after leaving the chiropractor. It does not always work.
Good neurosurgeon worked wonders on me.
   / Lower Back Brace Worth Recommending? #7
you are very brave, and very lucky!. the spinal cord is extremely tricky to fix, many times it comes out much worse, many just settle for metal supports which can severely restrict movement. Oxycodone is a safer and better option that truly works perfect in a case of permanent back injury..
   / Lower Back Brace Worth Recommending? #8
I don't know about back braces but the adjustable lumbar support on my new truck is sure nice. Make adjustments and I can walk upright when I exit the truck.
2016 FORD F550 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F550...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
CHALLENGER MT525B TRACTOR (A51247)
CHALLENGER MT525B...
