NoTrespassing
Elite Member
Just a question. I have a 4x6 Cub Cadet Big Country with a 20hp Honda engine. The battery has been dying a slow death over the past year but it's never failed to crank over and start. The dash display started showing battery voltage while running the other day. It was fluctuating between 8-10 volts on the display while driving it and giving a red light warning. After driving it off and on all day it failed to start. Then engine was still cranking pretty well and I put fuel in the carb and it fired until the gas burned up. I disconnected the fuel line and the fuel pump was pumping fuel all the way up to a short hose on the carb. After letting the machine sit for awhile it would fire but wouldn't keep running. After charging the battery it ran fine.
I'm going to put a new battery in it and that will fix my problem but I'm still curious why the low voltage is keeping it from running. The fuel pump seemed to be pushing plenty of fuel up to just before the carb. There's too many brackets in the way to see much and I don't feel like tearing into it when I know a battery will fix my problem. Could there be a solenoid between the fuel pump and the carb for some reason that's not opening at low voltage?
Kevin
Kevin
