Oil & Fuel LOW VISCOSITY OIL IN TURKEY FRYER?
   / LOW VISCOSITY OIL IN TURKEY FRYER? #1
dirtworksequip
Wheeling, WV
2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
Can I use Deere's Low viscosity hystat oil to deep fry my turkey? If so.............will it taste OK?
Sincerely, Dirt
   / LOW VISCOSITY OIL IN TURKEY FRYER? #2
Hmm. Only if it's HST oil.
HST-Hot Spiced Turkey oil:D
   / LOW VISCOSITY OIL IN TURKEY FRYER? #3
Oh, you can use SUDT also.
Super Ultra Delicious Turkey oil.
Matt, I thought it would be okay. I just wanted to check here first. I'm glad I finally found a good use for all that used oil.
Happy Thanksgiving to all TBN members!
Sincerely, Dirt
   / LOW VISCOSITY OIL IN TURKEY FRYER? #6
Go with Mobil 1 , you can run at a higher temp and it will be easier to poor out of the pot tonight when it is cold ! (might even get an extended oil change interval) Happy Thanksgiving and be safe !
   / LOW VISCOSITY OIL IN TURKEY FRYER? #8
Is it better to use synthetic oil to cook a turkey? Does dino flavor go with turkey?
Just returned from dinner at my parents. Everyone loved the deep fried turkey. Said ''it had a really unique flavor''
Sincerely, Dirt
   / LOW VISCOSITY OIL IN TURKEY FRYER? #10
Motor oil is not food grade. Might taste okay but would have potential carcinogens absorbed into the meat. Synthetic likely wouldn't but might have some metallics in the additives. Not sure what the additives are in a synthetic. There are plenty of heavy metals that I wouldn't want to ingest in dino motor oil, not too much in transmission type oil. Gear oil would be loaded with carcinogenic aromatic molecules unless it's synthetic or hydrotreated.
Melted wax is food grade, but the amount you need would be pretty expensive.
Have you checked into getting some Wesson, peanut oil or other type of cooking oil?
Ralph
Unused 12x20 Carport With 10' Fully Enclosed Side Walls (A55272)
Unused 12x20...
UNUSED IRGC40 Battery Powered Mini Golf Cart (A55272)
UNUSED IRGC40...
New/Unused Double Stall Portable Toilet (A57453)
New/Unused Double...
2016 FORD TRANSIT 350 CARGO VAN (A59575)
2016 FORD TRANSIT...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2000 Kiefer Bilt 20' Gooseneck Trailer (A59814)
2000 Kiefer Bilt...
