Low tech weed chopper...........your opinion.
   / Low tech weed chopper...........your opinion. #21
I once had a walk behind rotary mower that had a triangular plate under the deck that was attached to the rotating spindle with a sickle mower blade bolted onto the end of each point.
I made a mower somewhat like that with a pair of disc mower blades attached at the ends (with the matching stock bolts for the particular blade which allows them to swivel if the hit something solid) of a piece of 2" wide by 3/8" thick steel plate. I found the center of the bar and then used a rotary table on my mill to cut each end equidistant from center and also to locate each cutter's mounting hole which eliminated balance problems. I cut out the front of the push style mower deck enough to allow the blades to protrude so they were the first thing that would make contact with whatever you wanted to cut down.
It worked great for cutting down really large weeds, small trees and just about everything that a regular mower wouldn't handle.
   / Low tech weed chopper...........your opinion. #22
YouTube has at least 20,000 answers now,, in 2008,, YouTube had 6,,,,:thumbsup:
2012 Freightliner Bucket Truck (A55973)
2012 Freightliner...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
2020 DRAGON ESP...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
Zero Turn Mower (A55853)
Zero Turn Mower...
