Low tech weed chopper...........your opinion.
   / Low tech weed chopper...........your opinion. #11
Hmm.. I don't think the giant stalk cutter idea is going to pan out well.
i think i'd try to rig a motor up to the bush-hog and then tow it with a mount behind the truck somehow... or make it front mount.. if you really want to re-engineer the truck front end a bit.
I see an issue of 'junkyard wars' heppening out of this..
soundguy
Thanks for the input and advice. I'll take the junkyard wars comment as a compliment. Afterall This is a build it yourself forum, not copy major manufactures designs.I am sure the creation I comeup with will qualify for an episode of junkyard wars. Hope you folks have happy Easter weekend, we are headed to the ranch tomorrow PM.
   / Low tech weed chopper...........your opinion. #13
If it is just weeds, get a sprayer and spray your trail with roundup, that will clear your path right up. If you want the low level vegetation to survive use the roundup with a "wick applicator" basically a sponge that is drug onto the tall weeds.
   / Low tech weed chopper...........your opinion. #14
OK maybe I am not getting into the spirit of things But for around 150.00 a day you can rent a tractor in my area. I seriously considered that instead of buying one when I went to buy my new tractor. If you just have big weeds because of the rain rent the tractor for a weekend and you will have an amount equal to about one payment of a new tractor invested. To me you will not have the fun of building something in the Junkyard wars tradition but you will have something probably a bit safer and be able to get the job done while you are still fabricating motor mounts for the Junkyard wars regalia effort.
   / Low tech weed chopper...........your opinion. #15
not sure your weeds are, but a sickle bar mower will cut anything about 2" or less. A 20 hp motor would be plenty of power for this type of mower. Or you could look into a horse (wheel) driven sickle bar mower. Just attach it to your truck like a trailer and be on your way. Best part about the wheel driven model is that there is one less engine to worry about starting & maintaining
   / Low tech weed chopper...........your opinion. #16
You can buy a good 8N or Jubilee tractor for 2k. You seem to be a handy guy. Could probably get a project tractor for less than a grand. Seems like you'd have a lot of time and money into a 'sort-of working' solution with the truck idea.
Hammers make lousy screwdrivers...
   / Low tech weed chopper...........your opinion. #17
Do you realize this thread was dead in 2008?
   / Low tech weed chopper...........your opinion. #19
I love zombies!
   / Low tech weed chopper...........your opinion. #20
I once had a walk behind rotary mower that had a triangular plate under the deck that was attached to the rotating spindle with a sickle mower blade bolted onto the end of each point.
AGROTK HAMMER (A58214)
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
2009 Sterling Derrick Digger Truck (A55973)
2009 Sterling...
HUSQVARNA RIDING...
