Low RPM electronic Tachometer
   / Low RPM electronic Tachometer #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Anyone got any good sources for Low 0-3000 or 0-4000 RPM tachs. Must be electronic (signal from coil).
Working on this IH 300, it was converted to 12v and lost the tach drive. Would like to have a good tach. 3-3/8" hole.
Was doing some searching, and Datcon seems to be recommended frequently and there are some on ebay, but the part numbers dont jive with the part listings I can find from datcon. Some of their tachs feed off a magnetic pickup on the flywheel, or off the alternator or generator dignal for diesels. I dont want that. The one in specific I saw on ebay is datcon PN 103734, but cannot find that parn number anywhere else. So not sure of the size or how it is fed.
Any other good sources or brands for a tach. I am sure I am not the only one with a 12v converted old tractor.
   / Low RPM electronic Tachometer #2
when converted what alternator are you using can possibly get you the kit for installing tach to it supply part or brand if you can
I already got a tach. Its a datcon 0-4000RPM that gets its feed from the distributor.
Would have liked a 0-3000, but couldnt find any good ones on ebay and the cheapest elsewhere that was the right size was $150+
For $45, I took the 0-4000 one
UNUSED FUTURE BF47 47" BALE FORK (A57193)
UNUSED FUTURE BF47...
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
New Holland TC21D (A53317)
New Holland TC21D...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55315)
2025 Mahindra 6075...
(1) 7000 LB DROP LEG TRIALER JACKS (A57192)
(1) 7000 LB DROP...
Horse Weathervane (A55853)
Horse Weathervane...
