Low power Ford 1510 3cyl, where to start?
   / Low power Ford 1510 3cyl, where to start?
"So today I was noticing that if I have the tractor at idle (750rpm) and hit the throttle its pretty sluggish until it gets above 2200rpm and then it really revs high."Can you explain this statement;".... when it gets above 2200 rpm it really revs high"? Are you trying to say that with no load on the engine when you slam the throttle to high idle it's struggles up to 2200 rpm and then accelerates to high idle? What's the spec high idle rpm of this machine?
If you can put it under load with a drag harrow and pull that for a along time without any problem than you have enough fuel flow for that power output. At idle speed with a load on it, you don't have enough power to start or pull that load so the engine stalls unless you slip the clutch a little and increase the fuel flow gradually as you finish releasing the clutch-just like moving car in low gear.
The high idle spec is 3050rpms. What I mean by that statement is if I have the tractor sitting at low idle (750rpm) and hit the foot throttle wide open, the engine seems to struggle to rev, until it gets to 2200/2300rpm and then its like the engine comes alive. Its like the engine below 2200/2300 struggles and doesent want to "lug", but above that RPM the power output seems fine. I had to pull a stuck van up a hill this weekend and I had plenty of power since I was at WOT the entire time, but even just trying to idle around at less than 2200rpm the tractor struggles.
   / Low power Ford 1510 3cyl, where to start? #12
Seems likely that you would have checked this, but your brakes aren't stuck on are they?
   / Low power Ford 1510 3cyl, where to start? #13
SO this engine accel problem is a "no load" problem. Is the low idle setting spec @ 750 rpm? if so, since you say you have plenty of power at high RPM under load, restricted fuel flow isn't the problem. Some one with injector pump expertise needs to comment, but it sounds like either your low idle is too low or the metering valve is sticking when you advance the throttle. Try bumping up the lo idle by 100 rpm and see how that works.
   / Low power Ford 1510 3cyl, where to start? #14
It could be as simple as fuel QUALITY.. How long has that fuel been in the tank.. is it bio-fuel?
It could be the injectors need checking.. they get carboned up on the tips and that affects the spray pattern..that's the cheapest route
It could be the control rack on the injection pump is sticking.. run it at 1/2 throttle and operate the shut off lever back and forth..
Does the engine shut off and stay off or does it recover and run at 1/2 throttle??
When/if it recovers, does it run approx. the same speed or is it higher or lower than set previously??
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52709)
(INOP) 2019 KUBOTA...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
TUGGER TRAILER (A55745)
TUGGER TRAILER...
2007 Chevrolet Silverado 1500 Single Cab Pickup Truck (A55973)
2007 Chevrolet...
2018 Cadillac Armbruster 70IN Limo - 43,279 Miles, Professional Coachwork, Clean Executive Vehicle (A55315)
2018 Cadillac...
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A57453)
2012 Mitsubishi...
