Low Oil Pressure
/ Low Oil Pressure #1
EastTexFrank
East Texas, USA
Kubota Grand L4740, B2400 and F2680
I went over to the farm this past Sunday to do some mowing. I took out the 1979 MF 275 because it hadn't been used much lately since we got the new Kubota. I checked it over and greased it before I took it out. The oil was a little below the full mark but not too bad, probably less than a pint. The oil pressure gauge was running a little lower than I remember it (it used to run in the middle of the green) but it was still just in the green at PTO speed (1700 rpm) and went back towards the middle of the green when at idle. I made a mental note to top up the oil before using it again. Well, I was over at the farm again today and My S-I-L was off on the Kubota so I took out the old MF 275. I topped up the oil to full and this time the oil pressure was on the green/low borderline at idle and dropped into the yellow when at PTO speed.
The oil and filter were both changed last year and probably have less than 30 hours on them but the tractor has been sitting around for about 5 months. The oil still looks relatively clean on the dipstick.
I don't want to ruin the engine by continuing to run it so I'm looking for guidance as to the possible cause of the low pressure reading or things to try before I start ripping it apart or hauling it off the be fixed. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
Any help or suggestions would be greatly appreciated. Thanks in advance.
/ Low Oil Pressure #2
If I read your post correctly, the oil pressure drops as the RPMs increase. Is that correct? Has it always been that way? I would expect the oil pressure to increase as the engine speed increases until the relief valve opens, at which point it should hold steady.
Is the gauge mechanical or electrical? It almost seems like an electrical problem. /forums/images/graemlins/confused.gif
/ Low Oil Pressure #3
just a thought, any chance of water getting in the crankcase? oil sits on water so when you check dipstick you would only see oil, when oil and water mix it looks kinda like a milkshake, i would change the oil and filter, you never know if oil has sludged up and there is a restriction in the filter(although sometimes that will cause extra pressure). also, pull the wire off the oil sending unit and ground it, oil pressure should slowly climb to max-that'll tell you if gauge is working, if it is and oil change doesn't change anything, replace the sending unit. good luck!!!!
/ Low Oil Pressure #4
Another idea is fuel contamination in the oil thinning it.. making for the lower pressure.
Soundguy
/ Low Oil Pressure
</font><font color="blue" class="small">( <font color="blue"> the oil pressure drops as the RPMs increase? </font> )</font>
Yes it does and that's one of the things that puzzle me. I would have expected the opposite. The needle on the gauge has always run dead center of the green section, right in the middle of the gauge.
I think the gauge is electrical but I brought the manual home last night so I'll check to make sure.
I'll be going back over to the farm later today or tomorrow so I think I'll pick up a filter and oil and change them although I can't see how water could get in unless there is something very serious wrong. I'll also check for any bare wire problems.
Thanks for the ideas.
/ Low Oil Pressure #6
I hope the problem is the gauge. I had a 574 IH that did the same. It was the oil pump. I fed cows with that tractor so it was used every day. I noticed the pressure change and it worsened fast. Each day it was a little lower. Put in a new pump and the problem was solved. The screen over the pump can get clogged and show the same symptoms.
/ Low Oil Pressure
I changed the oil and filter on Sunday. It helped a little. At least now it runs in the green, but only just, and drops to the borderline between the the green and yellow when raised to PTO speed. That may be the result of using 15W-40 oil instead of the straight 30 weight. I also checked for any bare wires but didn't find any. Overall, the pressure is still running lower than it used to run. I think it's time to move on to the next step and check out the sender unit, if I can find it and make sure the filter on the pump isn't clogged for some reason. After that I guess it's gauge time and check out the oil pump.
It sure would make things a lot easier if I had a workshop manual for that thing. May have to see if I can track one down.
/ Low Oil Pressure #8
If it is in the green at idle.. but drops at throttle.. I'd sure check out something. Most worn oil pumps.. or loose bearing clearances tend to have low pressure at idle.. that gets a little better at throttle.
Soundguy
/ Low Oil Pressure #9
basic wrench turning 101 says, when shotgunning parts, prioritize most likely culprits, and replace easiest/cheapest first. If its electric driven single wire, check your grounding at gauge and engine first. Check wire run to gauge second. Price gauge and sending unit. Replace cheapest. My guess is grounding (first) or sending unit.
/ Low Oil Pressure #10
Sending units are cheap, (usually under $10). I would jump on that immediately.
/ Low Oil Pressure #11
for 15 bucks you won't have to guess about a dodgy sender and electric gauge... just get a sunpro mechanical one and screw it right into the block like an old international harvester! Or T it off and then use the sender and a 'real' gauge in conjunction.
Soundguy
/ Low Oil Pressure #12
Since the oil pressure drops at operating speed I think that it has something to do with the pump. A plugged oil filter would still let more oil pass at higher rpm. Bearings don't use much more oil at higher rpms than when sitting. So don't think that it is a bearing problem.
I suspect that it is a partially plugged inlet screen on the pump. As the pump tries to pump more oil the suction pressure drops. When this happens the pump will start to cavitate, and move less oil.
Possibly a good engine flush would be able to remove any sludge from the inlet screen. Not familiar with these tractors. Don't know how much work it is to pull the pan to look at the pump screen.
I would get a mechanical guage, and verify that the electronic guage is indicating the correct pressure. That the pressure is correct, or low. If it is actually low then I would have to check the pump inlet screen.
/ Low Oil Pressure
</font><font color="blue" class="small">( <font color="blue"> I suspect that it is a partially plugged inlet screen on the pump </font> )</font>
That sounds reasonable.
I've checked all the wiring I could get to on Sunday. When I go over to the farm later this week, I'll pull the dash to make sure everything is OK there. Next time I go to the "big city" I'll pick up a new sender and gauge just to eliminate those. Then I suppose I'll be left with the oil pump, either clearing the filter or replacing it.
Thanks for all your help and ideas. It's good to have a game plan.
/ Low Oil Pressure #14
I have to go along with catmando. . . . my case DC had a similar indication, mechanical type gauge. At idle, would read 22 pounds, as I increased speed, pressure would increase slightly, then all of a sudden drop off to 18 pounds. If I dropped back to an idle, it would bounce back to 22. Turned out to be a clogged inlet screen. Oil pump would cavitate when it couldn't suck the oil up. I was able to remove mine and clean without removing the oil pan. Fixed the problem.
Dexter trailer axles (A61567)
Dexter trailer...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2013 VOLVO VNL 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2013 VOLVO VNL 6X4...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A61573)
2018 Ram 1500 4x4...
2009 Ford Ranger XLT 4x4 Ext. Cab Pickup Truck (A61573)
2009 Ford Ranger...
