Low idle speed for B2910
   / Low idle speed for B2910 #1
RICKR
western NC
kubota B2910
Please,will someone tell me the RPM the B2910 is suppose to run at low idle?Mine runs at 1100.This seems too fast.Maybe anyone that owns one or a B7800 can tell me what theirs run at?Maybe Kubmec will tell me what KUBOTA recommends. Thanks everyone in advance.
   / Low idle speed for B2910 #2
Richard
My 2910 idles at 1000 RPMs. Before the 50 hour maintenance it was at about 1100. Dealer lowered it a little during the 50 hour checkup.
   / Low idle speed for B2910 #3
RickR,
That was one of my fist questions too...
My B2910 runs something like your B7800 [same engine].
Like Rick said, totally normal...no need to worry about it! /forums/images/graemlins/smile.gif
   / Low idle speed for B2910 #4
not sure what u mean by low idle? do u mean at the rpm with the throttle lever at it's loest setting? if so my b2400 will idle about 800 but i never do that, i always idel at about 1100. before i shut down i set the lever to this rpm for when i start up.
   / Low idle speed for B2910 #5
Mine idles at about 1050 RPM, so yours is about average. No need to worry about it. After you first start it up, you may want to run it up to 13-1500 until it warms up. That way your hydraulic fluids will warm up quicker and be ready to go to work sooner.
   / Low idle speed for B2910 #6
Mine's about 1050 as others' have indicated.
Have a good one,
Dave
Thanks everyone. I think I will turn it down to about 1000.I was just worried it might be running way too fast.
Yes, Frank that is what I meant.I just think it sounds better at 800 or 900 RPM.But like I said in my last post I will leave it around 1000 or a little more. Thanks. Also do you or any one else think it would hurt it to let it idle at 800. In otherwords will it damaged a diesel at a lower RPM if it is running smoothly?
   / Low idle speed for B2910 #9
Rick, the only time you want to run a diesel at low idle is when you're cooling it down. In other words, it doesn't run hot enough at a prolong low idle. If it was my tractor, I'd leave it where it is.
   / Low idle speed for B2910 #10
I can't speak for these tractor's as I'm relatively new to these small engines, but on the big boys you don't want to have a low idle because you'll get wetstacking. Wetstacking is caused when your cylinder temps aren't high enough to completely burn the diesel. The unburned diesel fuel will accumlate on the exhaust valve stem and eventually (over a period of time) cause it to not close completely. On a Cat 3126b they tell you that if you're going to be idling for more than 2-3 minutes to put it in what they call "high idle" which seems to be around 1100.
Just my .02
Regards,
Dave
PS - For every person who says that you might have a wetstacking problem there will be one guy who says that he leaves his truck/tractor running 24 hours a day at idle and has no problems. /forums/images/graemlins/smile.gif
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
(11) 2 PLUG VALVES (A52472)
(11) 2 PLUG VALVES...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
2014 FORD F-350 SUPER DUTY (A52472)
2014 FORD F-350...
APPROX 21 SIDEWINDERS (A52472)
APPROX 21...
